This command displays configuration and run-time parameters about MSDP peers.
| detail | Displays detailed information about MSDP peers. |
| remoteaddr | Specifies the IP address of the MSDP peer. |
| vr_name | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
N/A.
Use this command to verify the configuration and run-time parameters for MSDP peers, as follows:
The following command displays configuration and run-time parameters for MSDP peers:
show msdp peer
The following is sample output from this command:
Peer Address AS State Up/Down Resets SA_Cnt Name --------------------------------------------------------------------------- -d 54.172.168.97 14490 DISABLED 00:31:36 0 0 test *e 55.0.0.83 100 ESTABLISHED 00:21:04 1 0 to-Hawaii -d 124.56.78.90 2345 DISABLED 00:31:36 0 0 -d 221.160.90.228 23456 DISABLED 00:31:36 0 0 Flags: (*) default peer, (d) disabled, (e) enabled
The following command displays output from an MSDP peer with the IP address 16.0.0.2:
* Switch.8 # show msdp peer 16.0.0.2 MSDP Peer : 16.0.0.2 Enabled : No AS Number : 100.100 Keepalive Interval : 60 Holdtimer Interval : 75 Source Address : not known TTL Threshold : 0 Default Peer : No Default Peer Filter : not configured Process In Request : Yes In Request filter : not configured Maximum SA Limit : not configured Mesh Group : not configured Input SA Filter : not configured Output SA Filter : not configured State : DISABLED Uptime/Downtime : 00:00:02 Local Port : 0 Remote Port : 0 In Total Msgs : 0 Out Total Msgs : 0 In SA Msgs : 0 Out SA Msgs : 0 In SA Req Msgs : 0 Out SA Req Msgs : 0 In SA Resp Msgs : 0 Out SA Resp Msgs : 0 Time since Last Msg : 00:00:02 Hold Tmr Exp in : 00:00:00 Connection Attempts : 0 Entered Established : 0 RPF Fails : 0 Output Queue Size : 0
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
